Hi, I'm a new pool owner with a small inground pool. I was given no information about the pool when I bought the house but the pump and filter were working fine. But now I'm getting air bubbles in the pump basket, crackling sound from the multiport area, and bubbles from return jets.
I recently had the pool resurfaced and leak tested. There was a small crack in the skimmer which was repaired, but no other leaks were found. The pump basket lid was removed (I had never removed it before) during the process. Once the pool was filled I filled the pump basket and closed the lid. The pump primed but had vortex of bubbles, which I never had before. And the water drains from the basket overnight. The filter was not making noise at this point.
I did a backwash and rinse. After I moved back to filter I noticed the crackling from the multiport area. I've tried all the suggestions for finding a leak and all joints, valves and gaskets are fine.
When I turn the pump off there's a quarter size bubble remaining, but with the pump on it looks like a lot more air. Should I stop running the filter? I don't want to break the pump. Any suggestions to fix this would be greatly appreciated.
