Hi Friends, inching closer to actually swimming this summer.
I was mistaken above, I got the Hayward aquuatrol RJ model, which I now understand is direct return jet attachment. Because my above ground pool is partially buried, there’s only about a foot between the return jet and the ground. Not enough space to mount the salt cell vertically as I need to. As I see it my options are:
1. Try to return it and get the HP which can mount horizontally
2. Add a flow switch to the RJ (if that’s even possible)
3. Dig a hole so the salt cell goes a little below grade
4. Mount it higher, away from the pool, and have a gentle short sweep of hose from the cell to the return jet.
If #4 is an option I would lean towards that. But I’m not sure if the cell has to be run DIRECTLY into the return or if there can be a few feet of hose between them.
Much of this is temporary as I will probably be hard piping next season.
Grateful for any recommendations you all have.
