I need to build/hack together a waste hose for my Intext Sand Filter (SF80110-1) which does not come with one. Does anyone know what the collar size of this waste port is.
So the measurement is the diameter of the opening (port)? Does Intex have a special type of thread pattern? Should any type of 1.5" collar work?
Thank you so much for taking the time to answer my original question .
I ordered extra intex plunger valves, they will fit any fitting that the hoses will fit on, the drain port on the 6 valve way is this size. Mine always leaked there until I put the valve there, from there I used an extra pool hose to tie it into a drain line for backwashing etc.
