As Pat said, Your ta sounds like it’s fine where it is if your ph is stable.
If your cya is correct then you’re riding minimum with your fc which is not advised as it leaves no wiggle room between you & algae if any little thing happens like a higher bather load, high uv day etc.
Target
range is where you want to be
This is hard to measure & subsequently maintain without an fas/dpd test.
We also recommend reaching slam level for your cya & doing an
Overnight Chlorine Loss Test before closing to ensure you close algae free &
How Clear is TFP Clear?
& open that way too.
These things require accurate home testing so the kit is not a waste. The reagents are good for 2 years. You’ll likely run through those well before their expiration.
Is the water 60 degrees & falling in August there? If not then you’re closing too early. Is it still 60 degrees or less in June? If not then you’re opening too late
Winterizing a pool is essential for keeping your in-ground pool protected during cold-weather months. This Pool Repair guide will show you how to do it.
www.troublefreepool.com
Opening your pool can be stressful. This Pool Start Up guide teaches everything from start-up chemicals, covers, and more for your start up.
www.google.com
