Thanks in advance for the help.
On Sunday morning, I tested my water and there was zero chlorine. I used the Taylor FAS-DPD test kit (no pink). I usually have my pump on 24/7 around 1,500 RPMs unless we are using the pool and the salt cell is set to 25%, so there is no way it should be zero. I turned on the BOOST setting Sunday AM and then tested again Sunday night and still zero chlorine. I powered everything off, checked the salt cell (no buildup at all), checked the electrical connections, and turned it back on. I tested the salt in the water and it was 3,400ppm. I kept the BOOST setting on overnight and when I tested Monday AM there was still zero chlorine. Just to make sure my test kits were good, I shocked the pool Monday AM. Monday evening, the test showed 2.5-3PPM of chlorine, about what I would expect from the shock. I did a hard power off again and then ran the SWG at 100% overnight. This morning the chlorine level was still 2.5-3PPM, where it should have been closer to 6PPM. There have been no error messages on the SWG the entire time. Not sure what to do next.
