Greetings, Converted my pool to SWG a few weeks ago and have been working on an auto acid system to keep PH in check. I had a suction side saddle in place from removal of a Liquidator chlorine system and used that port to build a passive acid system. I used a acid proof adjustable valve and a 7 gallon storage tank. So far the system is working, but I lack the ability to change my dossage via any of my pool automation. I’m considering adding a Stenner pump to the system so I have the ability to automate my dosage amount.
The questions is, will a stenner pump work on the suction side or will the pump still pull acid through it when it is off? My other option would be to add a normally closed solenoid valve that I could turn on/off as needed via automation.
