- Feb 22, 2009
- 458
- Vinyl
- CircuPool RJ-30 Plus
Greetings! A new swim season is about to begin!
We are moving (DOT is putting a road through our property) and the new (to us) house has an even bigger and in ground pool (vinyl!)
That's the good news. The bad news is it is @32K gallons...and my Circupool is sized for 30K. I'll address that after I get the pump turned on and see how well it works.
The previous occupant told me things that the chem test proved to be a lie. Surprise, surprise. (He's a crackhead, so I didn't believe him anyway.)
FC - 0
CYA - 0
TA ->10
Ph - 6
Borates - 0
Salt isn't an issue yet.
The pool has a security cover, one corner is pulled back. Water is crystal clear, except for some leaf debris...and what looks like strings from a huge aquatic spider from the side to the bottom. Other flaky algae on the sides.
The question I have is in what order do I start adding chemicals, and since I do plan on using boric acid, what is the best mix of other chemicals to use? Also best source of them? Duda Diesel is where I bought my last BA and will likely use them again.
Water source is county utility. I would have expected at least some green algae, but none yet.
I understand the system and have had no issue with my current pool. Starting over at this scale is not cheap.
I have searched previous forum questions without a satisfactory result.
All helpful suggestions appreciated.
FC - 0
CYA - 0
TA ->10
Ph - 6
Borates - 0
