Hi all. I have following issue:
Does it make a big difference if water just skimming vs vacuuming and filtering?
I noticed that if i just purely skim, water is clearer as opposed as skimming and vacuuming.
I dont have dedicated line for vacuum. I do have a valve which directs water coming in through pump to either draw water from the top (skimmer) through bottom (drain) or half and half.
When i vacuum i place hose in skimmer. I leave valve half way so it will run vacuum and filter water through the drain. I find this option to cause water to get gray
