second green pool!
To follow the SLAM Process, you need your own test kit. You must test the FC and add liquid chlorine every few hours.
You need a proper test kit. I suggest the TF-100 or K2006C.
Without a test kit, you have no real basis to start with. Pool$tore numbers are suspect at best. Please do several things: Get a proper test kit so you can do your own testing while at the pool. Read the Pool School. 2-3 times. Read the ABC's of water chemistry. Understand the SLAM process. And realize that it doesn't change overnight. It likely didn't turn green in a day; it won't clear in a day either. The only immediate fix is to drain and refill. Then you'll still need to know how to keep it clear.
