Hi all. I've been using the TFP method for 2 years now and never had any trouble. This year, I'm struggling and could use some help. My pool water is persistently green despite adequate FC levels (typically 1-3 ppm). It started off the season clear, but this week went green and won't go away. Last night, I added 10 gallons of 10% liquid chlorine to try and SLAM the pool. FC only got to about 6 after that (I ran out of chlorine and the store was closed, so I couldn't go any higher). In the morning, here are my levels:
PoolMath says only 3 gallon should take me from FC 3 to FC 16 for SLAM, but after 10 gallons I only got to 6 so something must be eating it, right? Should I just keep adding more and more liquid chlorine? It is starting to get pricey, and I'm worried I'm wasting my time.
Any guidance is much appreciated! Thank you!
- Location - central PA
- Pool type - Fiberglass
- Sanitizer - SWG
- FC - 3.0
- pH - 6.8 (I know this is low - I dropped it to lower my TA and will be aerating to increase)
- TA - 100
- CH - 300
- CYA - 40
- Salt - 3300
