- May 3, 2007
- 16,960
- Plaster
- Hayward Aqua Rite (T-15)
The California Energy Commission (CEC) contracted a thrid party to perform some measurements for numerous pool pumps and posted the data to their web site. So far, it is the most comprehensive set of data for pool pumps that I have seen and allows one to directly compare the energy efficiency of pumps. The CEC performs measurements for two theoretical plumbing curves, soon to be three. From these four points (2 curves, 2 speeds), a pump energy curve and head curve can be inferred which is what the spreadsheet does.
The pump energy curve requires the knowledge of GPM, RPM and Watts for at least three operating points in order to do the curve fit. The head curve only requires two points of both GPM and Head for the curve fit, preferably at a high RPM.
Once the coefficients for the curves are known, you can then look up any other point. So for those without a GPM readout on their pump, they only need to know RPM and Watts to determine what the GPM and head is likely to be.
With the data you have, you could replace the head curve calculation to more accurately represent your pump's head curve although it shouldn't vary that much from the CEC data. If you had a watts measurement as well, then you could also replace the default pump's energy curve with your own. But first, you might want to confirm your measurements with what the tables indicate to see if there is much error.
