I just need a quick verification that I'm going about this with the proper mindset...
I just completely replumbed my pool and moved the equipment around. I am at the point where I'm wiring up the pump, heater, new salt system, etc and had a "wait-a-minute..." moment. I am replacing all the wiring with the same gauge that I removed, but when looking at the service requirements I'm preeeeeetty sure the old wire was too small. The old wire was mostly 16/3 submersible twisted copper and 14 gauge solid copper... the pump (pentair whisperflow model WFE-6) was hooked up to a double pole 15 amp breaker and heater (Jandy LRZ400) was hooked up to a 15 amp single pole breaker. The lights were hooked up to a 20 amp GFCI breaker, which makes me think the 16/3 might be a little light.
I'm thinking the 16/3 might be ok for the lights, but the pump and heater should be 12 gauge solid... right? Breakers / Wires Loads don't seem to be adding up right to me.
