- May 3, 2007
- 17,395
- Plaster
- Hayward Aqua Rite (T-15)
Yes, less load on the motor and less energy use as pressure increases. The "power" delivered to the water is related to both pressure AND flow rate. In fact, it is proportional to the product of the two. As you move from left to right on the head curve (lower head & lower pressure), the product of pressure and flow rate increases so input power to the impeller must also increase. Efficiency in the pump and the motor then come into play such that the electric power delivered to the motor is much higher than the hydraulic power delivered to the water.So, if i understand you correctly, there is less load on the motor if the pressure goes up. This would equate to less energy usage then or not
However, although energy use decreases with higher pressure, flow rate also decreases and faster than energy use so the energy factor, a measure of efficiency (GPM/watt), also decreases so the pump is less efficient even though it is using less power.
