I just drained, blasted, and refilled my 30,000 gal plaster salt pool. Cleaned all the grids. I haven't added salt yet. Our water here is very alkaline and high in minerals, I drained to lower the calcium.
I enter the test values in Pool Math:
30,000 gal plaster
FC 0 with target 4 - it tells me 128 oz (1 gal) 12% bleach.
pH 8 with target 7.6, TAlk 200 with target 60 - it tells me 1 gal 14.5% muriatic acid.
CA 300 CYA 0
I added both of those bleach (12% pool grade) and acid amounts, good new chemicals, and got a negligeable bump in both numbers. FCl went to 0.5, pH didn't move. By previous experience, I knew one bottle of acid wasn't going to do anything.
There was no stabilizer in yet, I just added 2 pounds (I like to go up slowly so as not to overdo it). Is that true that I'll need to add 160oz (10lbs) of stabilizer to get it from zero to 40?
What am I doing wrong? Why are my pool Math numbers so far off?
Russ
30,000 gal plaster
CA 300 CYA 0
Russ
