What's the best way to handle this situation? The pH is way low but TA is already high. This is on an 11k gallon above-ground pool.
No, I use bleach unless I need to add stabilizer, in which case I use dichlor.Big,
I suspect that you are using chlorine tablets... Is that true???
I use the TF-Pro kit for most tests.pH 6.2 with TA of 130
Very unlikely unless the CYA is sky high.
What are all of your numbers from a good test kit?
What is the history of this pool?
Pool Care Basics
PoolMath
Test Kits Compared
Not sure why CYA is zero. The pool is effectively in full sun and I rarely add dichlor. No chemical automation. The chlorine tab floater has been on the ground for two seasons. I've updated my sig, but here it is:Why is the CYA 0?
The pH is not going to stay at 6.2 with a TA of 130.
Can you fill out your signature?
Can you show the pool and system?
Do you have ozone, ionizers, CO2 or acid feeders?
Do you have pH or chlorine feeders?
If yes, are they automated?
