I don't think we have Leslies in the Chicago area, I should be fine with diluting until my drops arrive-thanks for the help.
Actually, it is just the opposite. The Chlorine/CYA chart is more aggressive.Smykowski said:Chlorine/CYA chart is more conservative. If you use the pool calculators numbers and use them as an absolute minimum, you'll be fine.
Keep it rolling and don't stop until you pass all three criteria (also in my sig)Kjohnson said:20 seems to be working-can't change now, I'm on a roll!!
Most likely the test would still be around 7.2 like you were consistently getting before, so I wouldn't worry about it.Kjohnson said:I should still wait until I pass overnight to worry about PH?
