New SWG pool - 0 chlorine
A couple things first:
1 - What is your current CYA reading?
2 - If you have zero chlorine, add some liquid chlorine ASAP. About 5 ppm worth.
Your signature is blank. What type of SWG do you have? Are there any red/warning lights noted? What is the current water temp?
Reactions: Mdragger88
I’ll add chlorine asap. I have trucell jandy pro.
I think the pool guy didn’t turn it on? I came to the unit and it showed “stand by”. I hit the power button now it’s chlorinating
The plaster is super smooth. Completely new.
now the generator says low salt. I checked the salt level and it gave me 3 drops. the 4th drop made it brown so 600-800ppm.
Salt is not added for 30 days after plaster.
Did salt get added already?
Was the salinity ever higher?
The level won't just suddenly drop from 3,200 ppm to 800 ppm.
