Your call. If water is easy to refill, sure. You can also just use the "filter" position and backwash as needed.and I would assume I need to vacuum with the pump on waste?
SportzTawk said:Ok, I was only wondering because when I tried vacuuming with it on Filter, It was just shooting everything back into the pool.
Backwashing will remove the debris the filter has caught. If the filter is full, your vacuum will have less vacuum, but your filter will catch even more stuff until the flow stops.SportzTawk said:OK, so let me throw this out there, and see if I'm correct.
Backwashing will clear the filter. So if the filter is full when I vacuum, it will just pump it back in the pool. But after backwashing the filter will be cleaned and I should be able to vacuum. Once the filter is full again, I would see it being pumped back in the pool...
Is that close to being correct?
Good point FPMfrustratedpoolmom said:Your sand could be channeled but sometimes with some filter/pump combos some algae - especially if there is a lot of it, will blow back into the pool.
