- Jun 1, 2018
- 14,096
- Vinyl
- Hayward Aqua Rite (T-15)
Did you use ahhsome to clean your tub?Over the weekend, I went ahead and cleaned out the tub, tried to remove any calcium waterlines and now the tub looks pristine. The filter is the only thing that needs attention, I went ahead and brought this however the warning labels scare me.
HTH Spa Care Filter Cleaner for Spas & Hot Tubs, 16oz (Pool Chemicals)
Robot or human?
It states it is very corrosive and must not be contact with skin, etc. I’m not sure if I should use this just because of the corrosive nature and the strong acids inside.
Should I return this and buy something that is less harsh or would it be okay to use?
If so, you are supposed to throw your filters in during the process then rinse them afterwards.
That is all I have ever done to mine. Alternatively you can soak them in a tub/container with a little dishwasher detergent (not dish soap) or tsp then rinse well. I believe that product is just expensive diluted TSP.
This should remove any grime/oils - if there are calcium deposits/scale that remains afterwards you can soak in diluted vinegar or very diluted Muriatic acid but you must go in that order, remove grime 1st then remove calcium otherwise the acid wash will solidify the grime & you’ll never get it off.
Also, don’t expect the filters to look new again, they will be stained even if they are clean, that’s fine.
Re: How to clean a cartridge filter
Re: How to clean a cartridge filter After 7 years, I've replaced my 4 cartridges in my filter (I could have gone longer, but the straps were starting to break and I figured I had a good run with these cartridges). The replacement cartridges for my Jandy CL340 were from Unicel® and they had...
www.troublefreepool.com
