phonedave
- May 30, 2012
- 2,010
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
Thanks. Again....much more difficult than the pool chemistry maintenance. This morning, I added some alkalinity Up and some pH Down. As the pH came back up, I added a few oz's of hydrogen peroxide tonight, as I read it will lower chlorine and also lower pH. So, I used half the amount "suggested" to see what happens in the morning. Trying to figure this out. I'll get there, and it may be liquid chlorine, or it may be a saltwater system. I love the simplicity of saltwater, but I've read horror stories in hot tubs and the salt cell replacement costs are ridiculous. But, I can't keep on with 6-7 chlorine levels, either. The Frog system has to go, I think. I also cut it OFF this morning and we'll see where chlorine is tomorrow after 2 30 minute soaks tonight.
It is really not more difficult. It is more "touchy" however.
What I mean by that is the concepts and chemistry are exactly the same, however things move a lot more quickly in a hot tub because it is a much smaller body of water.
This is my process for my hot tub, starting just before a water change.
Purge with Ahh Some
Drain the tub and clean everything.
Refill
Start out using DiChlor (Chlorine granules) as needed until my CYA gets to 30-40 ppm then switch to bleach
Run my CH up to about 300 using Calcium Hardness Increaser - I do this to prevent foaming
For a week or two I test pH and TA and play around using acid and baking soda until they are where they need to be and stabilize
I then move to the following schedule
I add measure FC/CC and pH and add bleach and acid every 2 or 3 days and bring the tub up to the upper FC levels for the CYA and to correct pH if necessary
If I am going in the tub, and have not measured FC that day, I measure and add bleach if necessary
After using the tub I add 2oz of bleach
Once a week I add a scant oz of Aqua Clarity
So I use bleach and acid on a regular basis
Baking soda for a week or so after start up
CH increaser once after start up
Aqua Clarity once a week
I would love to add a SWCG to my tub. I just have to work out how to get power to it (safely and in code)
