our IC40 is nearing the end of its life, i guess, even though the display says it is only 60% used it's almost 8 years old...so we're probably getting to the point where it will need to be replaced. trying to coax one more season or two out of it though. on that note, when i turned it back on for the summer two weeks ago, the cell light was blinking. i checked the plates, and didn't see any obvious build-up...but did an acid clean anyway, and there was quite a bit of bubbling - and it started working again. last weekend i cleaned the filter, and had to take it apart to re-lube the o-ring after a small leak was observed there. the filter is now sealed and not leaking, but the cell light is blinking again on the IC40 (just started in the last day or two, as it wasn't blinking on saturday when i took the filter apart and re-lubed the o-ring).
i'm going to do another acid wash again today to see if i can get it running again, but is there anything else i can do to try to get at least one more summer out of this cell? like i said, the display says that it's only 60% used (it's oversized for our 10k gallon pool), but i'm not about to do an acid wash on it every two weeks all summer...i'd just use liquid chlorine for a few months before doing that. or am i just SoL and need to replace it now even though it supposedly has life left?
edit: acid soak in progress, it's definitely dirty again. a lot of fizzing. so i guess the question is how do i keep this thing clean enough to make it thru the summer? ideally i would get at least this summer out of it, then replace it next year when i turn it back on after the winter...
