Hello, so my problem is i have 2 return lines in my inground pool. Only one of them is flowing. The other barely flows if at all. If i cover my hand over the one that is flowing then the other return line flows. If i let off then it stops again and the one that originally was flowing flows again. I changed the sand that didnt help. I replaced the 8 way diverter valve on top of sand filter. I dont see any leaks. This low flow only happens when i put the sand filter into either recirculate or filter mode. When i do this the pump pot is only half and low flow out of only one return line. The big mystery is that when i put sand filter into backwash or waste the pump pot fills fully and the water flows strong. So i think that ruled out impellar but i dont know. So i know theres not any clogs in the suction side because of strong flow in either backwash or waste mode with diverter set to full, main drain or skimmer. Could there be a clog in the return line? Would to much sand cause this? Im at a loss at this point.
