Logging Test Results
Is there a way to print off test results? The warranty department is asking for test results on an issue we are having.
If you click the square box with an arrow pointing in the top right corner of the app it will allow you to email yourself the log And then you can print them out from there
Manufacturers likely won't accept your results. They want weekly 'professional' tests.
It doesn't matter your tests are more accurate, they have an easy out of honoring the warranty.
To answer the question with another option, screenshot the log and then email and print it.
