- Mar 14, 2016
- 227
- Plaster
- Pentair Intellichlor IC-40
Thank you pooldv
I will be buying a bag of conditioner tomorrow after work. I already added liquid chlorine in per pool math an hour ago. I will be checking in a few minutes to see where it is at. I had already put 8lbs of conditioner in the pool when it was first turned up a few months back.
If I am reading it correct I will need to add 2 lbs 8 oz of conditioner per pool math.
As for bleach I have looked at the stores and at +/-$4.00 it is about the same as chlorine is it not? Where are people buying bleach where it is noticeably cheaper? I like the BBB method and will use it as needed. I have already used A&H Baking Soda for my TA, that worked great and was WAY cheaper than Leslies Alk UP.
The salt cell will give an error if there is low salt.
eostrike,
Raising CYA up to 70-80 will reduce your FC loss to the sun and therefore your daily FC consumption. The difference will be noticeable and it is worth doing. Bleach/liquid chlorine is the same thing just different percentages, bleach 6-8.25%, LC 10-12%
