Thank you Jim. I'll clean it up and replace the bearing first.Brant,
I can't tell if the "black" is from the bad bearing or from the coil...
I'd clean it all up.. If you can't see actual damage to the coil, then I'd get the front bearing replaced.
I can't remember the exact place, but there are plenty of shops that sell bearings.. They can look at what you have and tell you what you need.
I suspect you whole pump is quite old, so Allen is right that a new pump makes the most logical choice, but that might not be the most economical choice.
The New IntelliFlo3 is not a drop in replacement for what you have. A standard IntelliFlo would be.. I "assume' your automation system is still working for pump control, if so, then both the IntelliFlo3, and the standard IntelliFlo, can be controlled by your current automation.
Correct, my automation is still working. The current plumping has the hand screw-on type union nuts, on both connecting points and also at the filter connecting point, which will make it easier to adjust. I'm comfortable with making further adjustments to the plumping to fit if needed (knock on wood).
Out of the pump options, what's recommended or what's the difference? Do I need a 3HP since that's what I'm replacing?
- Intelliflo3 (seems like the latest/greatest, true?) - assuming I do not need the relay board or touchscreen if my automation stays the same?
- Intelliflo VS (multiple options) - is this the new version of my VS-3050?
- VS-3050 (I think this is discontinued and expensive), but a direct replacement. Why buy this over the Intelliflo3 or other that are less?
- Whisperflo - too many options to list
- Intelliflo FX - Also variable speed, similar price
- Pentair Trade Grade products?
The choices are overwhelming and a bit confusing, so hoping for direction on a specific model or two and why.
Thanks!
