That is probably from the impeller ring which might need to be replaced but the impeller doesn't look too bad. If there are any large gouge that would make it imbalanced or not seal properly against the impeller ring, then I would replace it.
What do you mean by the impeller ring? Is that the ring that is lodged into the diffuser opening? If so, I can't find this part. I thought it was included as part of the diffuser?
