Once whisper quiet is now much louder. Thoughts? I took it apart and didn’t find anything stuck in impeller. Pressure is good in pool and otherwise working as normal. Just louder. Trying to figure out if motor or possible impeller or seal issues.
I have a new pump motor coming. I think it’s probably that, but I thought maybe the pros here had some thoughts. I wasn’t sure if an impeller problem could cause it.Hi Jerry, Oddly mine started doing the same thing recently. I just came on here to look for answers. Sorry I cannot help more but tagging myself in case you get any replies.
Sorry you fell through the cracks. Let's call you @ajw22 @Jimrahbe @JamesW and @1poolman1, all Pentair/pump whisperers.but I thought maybe the pros here had some thoughts.
If there is nothing stuck in the fan, that is bearings. Leaking seal would cause that. The sound didn't just start, it began a while back and wasn't noticed or was ignored. Happens all the time to pools. Many times, if the pump runs higher speeds at night when one is sleeping, the sound isn't heard.Once whisper quiet is now much louder. Thoughts? I took it apart and didn’t find anything stuck in impeller. Pressure is good in pool and otherwise working as normal. Just louder. Trying to figure out if motor or possible impeller or seal issues.
I ordered the Pentair 350305S which is the replacement motor. I found it online.Yip looks that's our route too. Which one did you buy and from where? Thanks
