Impeller Issue: 1.5HP Hayward Self-priming Super Pump (C48L2N134B1)
DigitalDJ
6
New Jersey
Hello everyone,
We live in New Jersey. Pool was closed last winter and working fine at the time. Pool was opened yesterday and when we started the pump the impeller would not spin and the pump would overheat and click off.
- Capacitor was tested and was not the problem.
- Checked the impeller and there was some debris. Cleaned that.
- Impeller would not spin so I forced it by hand to spin both ways.
- Put it all back together and the pump kicked on but is now super loud.
- Also, the impeller and rod now spin with little resistance…
Did I break something and can it be easily fixed?
Thank you in advance!
Welcome to TFP.
Bad bearings that froze over the winter.
What model pump?
How old?
You can replace the motor if the rest of the pump is in good condition.
Post pic of the motor data plate.
Much appreciated! Thanks for all of your help.
One more question: Is there a way to tell if a bearing is bad once it is removed? Our current pump has a front and a rear bearing. I am just wondering if there's a way to tell which one is bad. Thanks!
Only by disassembling the motor and examining the bearings.
