You can add what the poolmath calculator says... give it an hour to mix while your pump/filter is running, then test again to confirm whether or not it was accurate... it is what I did at first.
Just a couple of more thoughts:
1. When you start your pump/sand filter, keep an eye on the PSI and water flow. The iron will clog up the filter quicker than expected and you will need to backwash and rinse (possibly multiple times until the water clears).
2. Give the filter at least 48 hours to see if it will clear the iron before adding salt. Then add salt and let it dissolve 24 hours, with the pump running, before starting the SWG (continue using bleach until the SWG is producing chlorine).
The experts can correct me if this doesn't sound right for your situation, but this is what I have experienced.
I can only get 6 oz and 4 tps if I enter "0" (NOW) and "1" (TARGET) FC values for a 4500 gallon sized pool which is too low. You actually want the FC between 3-5 ppm. 20 ounces (2 cups 4 oz) will increase your FC by "3". 33 ounces (just over 1 quart) will increase FC by 5 ppm. It's very important at this stage to never let FC drop below 3 to avoid algae. So with the FC drop tester you have, do your best. I know we don't want to "make the iron mad", but it's better to be a little strong right now and avoid algae than to have a SLAM on our hands.
Increase your FC to between 3-5 for this evening. Tomorrow I would add 1.5 cups in the morning, 1.5 cups in the afternoon, and 1.5 cups in the evening. If you find yoru FC test to be very low between any of those tests, increase bleach slightly by about 1/2 cup. Just try to keep it over 3 at all times.
It's because your NOW (starting number) is already "2". So in effect you're only increasing FC by 1 ppm. Do you see?
My example before was from going from "zero" to 3.
Many of my examples above were to help either illustrate how the calculator works, or to give you an "idea" how much bleach will increase your FC. So tomorrow for example, when you wake-up ... if the FC is already still a "2", then your example above is fine (going from 2 to 3), and you would only need to add a little bleach (little over 6 ounces) to increase FC to 3.
I think you have it. We'll just let you enter the Poolmath numbers you need based on what you test and go from there.
I know, I am really hoping it will come today because I cant figure out what my chlorine or CYA level is. The drops say FC is between 2 and 3 still and that doesn't seem possible after all the chlorine I added. The sticks say it is between 5 and 10. Thanks for the paper towel tip. I am actually using fabric over the skimmer right now, I am a fiber artist and the iron is making a lovely decorative print on the fabric. That's the bonus to all this hassle I guess.
Proper lighting is critical for the CYA test, so you want to test for CYA outside on a bright sunny day. Taylor recommends standing outside with your back to the sun and the view tube in the shade of your body. Use the mixing bottle to combine/gently mix the required amounts of pool water and R-0013 reagent, let sit for 30 seconds, then gently mix again. Then, while holding the skinny tube with the black dot at waist level, begin squirting the mixed solution into the skinny tube. Watch the black dot until it completely disappears. Once it disappears, record the CYA reading. After the first test, you can pour the mixed solution from the skinny view tube back to the mixing bottle, shake, and do the same test a second, third, or fourth time to instill consistency in your technique, become more comfortable with the testing, and validate the CYA reading.
You're okay! The FC will come down soon. Better to fight-off algae right now. I'll give you some more notes shortly.
