- Jun 22, 2014
- 47,857
- Fiberglass
- CircuPool RJ-45 Plus
If your water is beginning to turn to brown, that is a fairly good indication there is iron in the water - very common for a well. When chlorine is introduced to water with iron, it changes color and can begin to stain the pool surfaces if left that way for very long. When you go to the pool store to a water test, you can take a pool sample, but I also encourage you to take a sample from the source (hose) "before" chlorine is added as well.
It's a shame metal in water is such a pain in the neck, but as you said so well above .. "It is what it is". In some areas, that's all you have to use. Here's a few tips to try and help you with metals in water:
- Pre-filter as much as possible. Even though the fill has begun, you have more water to add, so try any pre-filtering like running the water through an intermediate container filled with absorbent material to catch the iron before it gets to the pool may help. Once your husband connects the hoses, you can also add some paper towels to the skimmer which may collect some iron while it is in that brown "precipitated" stage.
- Pre-filtering will only get so much. After that, you need to manage chemically. That means a relatively low FC level. That may be good for you since you have an SWG that usually runs with a higher CYA and lower FC level throughout the day.
- Also test and maintain pH on the low 7s (7.2-7.4) which may help.
- Prepare to purchase a sequestrant.
My heart goes out to you two for your valiant efforts to try and beat the deadline for Friday. Just when we thought you had a simple algae issue, we find that your well may be the culprit. Tomorrow is another day. We'll be watching for your updates. Once you fill completely we'll assist with final chemical adjustments based on your SWG and see if we can help you keep the "brown" from getting too bad.
For future reference, here is the TFP Pool School - Metals in the Water and Metal Stains page which you may find informative. Try to have an nice evening.
- Last but certainly not least, that proper test kit is exceptionally important to you folks to ensure you can test the water at home at any time needed - accurately. Pool store testing is notoriously wrong, and so are test strips. Please keep that in mind.Sequestrant is a chemical that binds to the iron in the water so that it can't form stains or turn brown. Sequestrant breaks down slowly, so you need to add more regularly. ProTeam's Metal Magic and Jack's Magic "the Purple Stuff (SWG)" are some of the top sequestrants. You can also find other brands with similar products, some of which are noticeably less expensive. Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective.
