On a side note... thinking about your ladder.... Pull it out of the pool, and be sure to wipe down and rinse the UNDERSIDE of the steps as well. You want to kill everything you can before you re-fill.
Since you are sensitive to bleach, do you have anyone else around that can do this part for you?
Hey you two! How is it going? I figured shortly you'll be done with your pool "housekeeping" and ready to fill. So in preparation for your new water, I wanted to give you this game plan forward so you can start right away as soon as you have the water level up to the skimmer to start the pump: (FYI - I used 4,500 as my gallon capacity on the Poolmath Calculator). You can double-check or adjust if needed.)
1. Increase CYA to "70". That is necessary for your SWG pool. If you still plan to use liquid, that's about 107 ounces. If you use granules, it's about 42 ounces.
2. Add the required amount of salt. 120 lbs should get you close to about 3,100 ppm.
3. You'll need to add a little bleach for the first day or two until the SWG was adjusted properly. On day 1 you only want about 3 ppm (2 - 2.5 cups of 8.25% bleach). On day two, you should increase FC to between 4-6 ppm and NEVER let FC drop below 3 (me personally I'd lever let it drop below 4). Use regular bleach to help until you get the SWG adjusted properly.
4. PH should be in the mid 7-s (7.5-7.8). If you need help adjusting pH up or down, just let us know.
That should just about do it for today. Please make sure to order your TF-100 test kit as soon as you can. For now, the Poolmath calculator will be a big help, and a simple Wal-Mart HTH drop test kit will help with pH and low FC levels. But eventually you'll need the TF-100. Oh, I highly encourage you to also include the "Speed Stir" magnetic mixer to help you mix efficiently.
Good luck, and let us know if you have any questions.
Happy 4th to you as well... sorry it was a back breaker for you 2.
tomorrow is another day.
There is chlorine in tap water and it should be fine while filling.
We have well water, so it has no chlorine in it. The pool has only filled 13 inches in almost 4 hours and it is a very intense sunny day. Worried about losing the water again at this slow fill rate in this heat.
According to my calculations you have about 1136 gallons in the pool now. Per pool math, you can add about 4 oz of 8.25% bleach which will bring your FC to 2. Just make sure that you disperse it with the water hose so that it doesn't concentrate on one area.
