Sounds good!! But I don't need to keep my FC level up right? My target FC is 4-7 so I should start letting it go down?!
No. Just keep FC at 12 another day or so and let the filter work. Do what you can to improve circulation down at the deep end - open the main drain, point a return down there, or set the vacuum in the deep end on its side so it has maximum flow and is drawing from down deep where that cloudy stuff wants to settle.I'm not sure how to keep slamming when my FC is at the shock level for CYA at 30??? What should I do? This may be my previous pool store question---but do I need a "clairifier"?
So, I'm only adding 2 to 3 jugs of bleach a day---should I have turned my chlorinator back on? You can still see the main drains in the deep end but it's not getting any clearer. I have the main drains open & i run the dolphin in the deep end every day. Am I missing something on why it's not clearing up? Also, is it ok to swim?
When you said chlorinator, I assumed salt water generator.We don't have salt tho??
