draining pool
I am currently draining my gunite pool on waste, using only the main drain, the pump is working fine and there doesnt seem to be any air leaking anywhere, but there is a small amount of water being returned into the pool through the return jets. What could be the problem?
Hello and welcome to TFP! :wave: Perhaps if you have a multiport valve, there is some water getting past the waste cycle via the spider gasket?
By the way, please take a moment to update your signature with all of you equipment. You can go to the "Setting" link above, or click EDIT YOUR SIGNATURE. It will help us later. Nice to have you with us.
