Ah, good advice on just putting something in the skimmer drain hole to block the water. I think I have a ball just slightly larger than the opening that should seal it pretty good.
So the pool completed filling up yesterday afternoon to just below the top of the skimmer. For some reason my corners are a little high, but otherwise things are looking pretty good. I wonder if not filling those last few inches are the cause of the slight bow I still have on the sides?
Water level just below top of skimmer.
Slight bow on uphill side:
And on downhill side as well:
That said, nothing is leaking and everything otherwise appears to be holding up well, despite some serious downpours over the last few days.
I added gallon jug of chlorine yesterday afternoon and tested with my TF-100 kit this morning, and these are the readings I got:
FC 2.0
CC 0
CH 25
TA 30
CYA 0 (the water was crystal clear so the black circle was visible when the test tube was full)
pH was below the scale in my test kit, so I'm estimating it to be around 6.6 or so.
Recall that I filled the pool using well water, running it through an ecoone hose filter.
I'll start reading up on how to bring up pH and hope that CYA will follow. Probably wouldn't hurt to pour in another jug of bleach once the sun has set.
Any pointers on best way to get my water params in check while I begin to read would be most welcome!
Time to update my profile as well with my pool info!
