Just replace a malfunctioning salt chlorinator. Free chlorine readings remain nil.
Large kidney shaped in ground. Approx 30k gallons.
salt level approx 3500ppm.
CYA 30-40
hardness 400-500
alkalinity 150.
Ph 7.5.
I assumed I had a high chlorine demand and the new salt generator wasn’t able to overcome alone. (Not chlorine lock b/c the CYA is not high). So…i put in 12 gallons of liquid shock (12.5%) last night. This morning when i tested the free chlorine level was barely reading…still less than 1ppm.
here’s another conundrum…I’ve battled low CYA all year as well. I’ve added several pounds of granular CYA. It failed to budge the CYA, so I decided to add liquid CYA. I’ve added 4 gallons of liquid CYA and it only raised to 30-40 (previously unmeasurable).
Does anyone have any ideas? What am I doing wrong?
CYA 30-40
hardness 400-500
alkalinity 150.
Ph 7.5.
