So the TS-100 kit is $83 and you have to get to $100 for free shipping (or else it's $13 shipping). So what reagent(s) am I likely to use up first that I can buy to get to $100?
Meh...Read and prepare.Now I just hope I don't screw it up.
Cal-Hypo adds calcium the way trichlor adds CYA. The accumulation isn't as rapid, but it will eventually accumulate to the point that you'll need to do a partial drain or water exchange. Unless your pool needs calcium it's best to use only liquid chlorine or an SWCG.Related question in relation to trying to reduce CYA, can a cal-hypo shock (such as this in powder form to mix with water then add to pool water) be used in addition to the occasional "regular" puck style 3" tabs that contain CYA? I have a lot of Leslie's triclor tablets that I bought before I realized they raised my CYA levels but I hate to just not ever use them--they were expensive!
Save the tabs for vacation or when your cya can stand the increase. Be aware that Trichlor increases cya, fc, salt, & lowers ph.Related question in relation to trying to reduce CYA, can a cal-hypo shock (such as this in powder form to mix with water then add to pool water) be used in addition to the occasional "regular" puck style 3" tabs that contain CYA? I have a lot of Leslie's triclor tablets that I bought before I realized they raised my CYA levels but I hate to just not ever use them--they were expensive!
Save them for over the winter when the pool isn't running. Since you have a fiberglass pool, I assume you don't drain it.I have a lot of Leslie's triclor tablets that I bought before I realized they raised my CYA levels but I hate to just not ever use them--they were expensive!
Do u close after pool temp is below mid 60’s & open before pool temp gets above mid 60’s?Save them for over the winter when the pool isn't running. Since you have a fiberglass pool, I assume you don't drain it.
Keep a few in a floater. My CYA is almost always back down to nothing each spring when I open back up and my water is green. I'm gonna do this this year and see what happens.
As a fellow new user in the last week most of the tests are stupid simple to do. Cya can be a bit tricky (I’m still trying to get it) the fc drop test with a speedstir is easier than trying to decipher what shade you are looking at on a test stripThanks again for all the comments! I am sure I will have more questions once I try the test kit.
For practice, you can get a 50ppm calibrated solution from tftestkits.net: R-7065 CYA Standard 50ppm (2oz). Do the CYA test with it instead of pool water. What you see when you fill the CYA test tube to the "50" mark (or "40" mark, depending on your test procedure) is what you should look for when you do real tests.Cya can be a bit tricky (I’m still trying to get it)
That’s awesome I will add that to my order as I need some reagents soon ( a slam will run through them lol )For practice, you can get a 50ppm calibrated solution from tftestkits.net: R-7065 CYA Standard 50ppm (2oz). Do the CYA test with it instead of pool water. What you see when you fill the CYA test tube to the "50" mark (or "40" mark, depending on your test procedure) is what you should look for when you do real tests.
So no cover?I base it more upon the weather, as my pool is heated. I shut it down as soon as the temps get uncomfortable for swimming, usually mid-Sept. Then open back up around April.
But even when the water is below 60, it gets nasty. I have a lot of trees around my pool and I don't scoop the leaves out regularly, so some settle to the bottom over the winter.
This was Mar 17 the this yearView attachment 436150
And April 5th after a SLAMView attachment 436151
It took 18-20 gallons of chlorine to clear it up this year. I also added 14 lbs of stabilizer. I'm hoping to cut that back next year by floating some tabs all winter.
