- Apr 24, 2022
- 230
- Plaster
- Pentair Intellichlor IC-40
I’ll test here in a moment, I still have 10 bags of salt… lol math isn’t mathingFor the salt test it’s likely to expire before you use it all - at least in my experience.
That’s 108ppmMy sodium is on my city’s water test, 108 mg/l
Tested: 1 drop…Have you tested your fill water?
1950+1500= 3450
Your math is mathing!
10 ml, I follow the testing instructions…Can you tell us your testing procedure, something sounds very off. How much water in the vial before the magnetic spinner is dropped in?
They are unnecessarily difficult and start with 'Fill the 25ml vial...........' It has fooled alot of us.10 ml, I follow the testing instructions…
I haven’t made that mistake yet, but I’m sure I will.They are unnecessarily difficult and start with 'Fill the 25ml vial...........' It has fooled alot of us.
More than once.
I’m taking it to a pool store just to see what they come back with. The city wouldn’t go up that much.. that’s an insane amountYour city's water report for salt is a snapshot in time. The reading could have gone up.
No idea how your salt level got to 1400-1600 in that short a time.
But you can't change the salt content without draining/refilling or adding salt.
Use your results and add enough salt to get to the lower end of the recommended range for your SWG.
Monitor the salt every two weeks for a while to see if you see it trending up/down - then monthly.
Report the salt level in multiples of 200 as that is what the K-1766 test shows.
Fill out your signature with pool, pool equipment (including manufacturers and model numbers) and test kit info. Be specific.
This allows us to provide you with help specific to your pool without needed to ask you each time.
I did my startup, unless someone decided to donate that much salt.. idk.. of course as I took it to the store to test, their system crashed…So. The reason the 10ml was of particular importance was because if you *did* subconsciously foul it up, using 2.5X the sample nets a 2.5X result. Which would have left your salt at 600, 450 for startup and 150 for city water.
For all #s it could have been, for that to just happen to line up, is amazing.
Or. Somebody from the PB showed up early and dumped in salt.
if you’re at 3450 on the test turn the swg on & see what she says….I did my startup, unless someone decided to donate that much salt.. idk.. of course as I took it to the store to test, their system crashed…
I will check again as well, I don’t think I can send a video, too large of a file. I’ll ensure it’s 10ml as I am very sure, but everyone keeps saying it and now I doubt myself the only thing I am very sure of is according to pool math , the 6 bags should put me at 1950 ish
Almost gets me everytime!They are unnecessarily difficult and start with 'Fill the 25ml vial...........' It has fooled alot of us.
More than once.
