I recently took on a commercial pool and have been running into trouble maintaining proper balance. The site has 2 Stenner pumps, one for chlorine and one for acid, which I diluted today 1 to 1. I have the chlorine pump set at it's max setting and the acid pump at it's lowest but every time I arrive and test the water, chlorine is at a 0, pH is around a 6 and alkalinity is at a 0. I balanced the pool again this morning and had nearly perfect numbers before leaving the site. I went back this evening and the numbers were back to where they were when I arrived. I am in Florida and the sun is intense so I expect some trouble with chlorine but i've never seen the pH and alkalinity dip so low because of it. The pump itself is pulling roughly a gallon a week of diluted acid and this is a 36,000 gallon pool. Any suggestions?
