Fralo, you do need to brush your pool every now and then... The more frequently, the better. Your filter can't clean your water properly if all the tiny debris is sitting on the bottom.
Unless you are getting monsoon rains, the rain should have little effect on the pool. Just keep your FC at shock level regardless.Well I started my SLAM with in and off showers since last night. Now the sky is completely gray and there has been a slow drizzle for over an hour now.
Will it all be for nought?
Do you lose less than 1ppm of FC overnight?I know this is a tough question to really answer, but how clear must my pool be before I can think my SLAM is complete? Should I be striving for that crystal clear look, or is that not realistic? It is much clearer than it was and I can see the bottom pretty well. Although I still think it has a milky look. This is more noticeable when I clean my paper cartridge. The water around the cartridge does look milky.
So far I have been adding bleach to it every 3-4 hrs in order to reach my shock level up to 12, except for during the night obviously. I vacuum everyday and get less and less dirt each time, so that part is definitely going well.
Perhaps the milky look is a result of all the chemicals I added at the beginning, and is not something that a SLAM is not meant to address?
How did you do with the overnight chlorine loss?Yes I believe so. Will check in the morning to verify. Thanks for your help.
