Okay so the more videos I watch on YouTube the more I get confused. When doing the chlorine tests do I scoop the powder into the water or just use the drops? Or both? Is this more than one method?
Yep. I don't use the OTO at all personally, too hard to approximate a number.Ah! I see. So the FAS-DPD would seem to be the one you would routinely conduct, since the OTO is simply to determine if there is any chlorine at all, which is probably pretty rare.
Hey, you guys are alright.
You should maintain your FC at 40-50% of your CYA until your water is clear again. Do not let it drop below 40%, or you will simply be extending the process.
I don't see where you've posted a CYA reading since you said it was 0? Have you added and/or measured any CYA in your water?
I didn't know I was doing a SLAM. I have been doing nothing more than adding about half gallon of bleach until my test kit arrived, which came yesterday. I have yet to get a vacuum and brush to do the SLAM anyway. Since the water has started to clear up some I thought I didn't need to do that.
Just wondering where to go from here. Thanks so much.
