- Jun 4, 2022
- 151
- Vinyl
- Hayward Aqua Rite (T-15)
No.Hopefully you're not closing yet as there's too much time for algae to kick in.
That's the only time we reccomend it. And even then half of us still don't use it. We are hardcore against its regular use during the season. It's a common sell by the pool store to either make up for improper care or as preemptive care for improper care.I was surprised to see one of the above comments indicate that algecide is used in closings
When the water temp is under 60. It can hang on the fence for a while, or warm up again a couple weeks after closing. It's not an exact science and it's just as important to open early and get a jump on it.But what the general recommendation as the proper time to close
That gives me the temp to shoot for . Is it the same for opening? And should I put 3” pucks in a floater over the winter?That's the only time we reccomend it. And even then half of us still don't use it. We are hardcore against its regular use during the season. It's a common sell by the pool store to either make up for improper care or as preemptive care for improper care.
When you maintain your chlorine levels, you don't need extras. If you have time to add extras IMO, you can add the chlorine in the first place.
I rolled for 6.5 years on dumb luck. It's my favorite kind.So my water temp was probably where you suggested- just dumb luck.
No - it’s a mesh loop- loc coverAre you using a solid cover?
So now my pool is crystal clear again. The CYA is between 50 & 60. My fc this morning was 26.5 a little over SLAM target. My plan is to let it drift back down over the next few days. I will do OCLT tonight. And agin each night till it passes.I rolled for 6.5 years on dumb luck. It's my favorite kind.
At both houses the pool was obnoxiously front and center (err. Rear and center) and I wanted to delay looking at the trampoline as long as possible. The aesthetic side of things lined up with the science side of things.
Yes. Everything but the PH is valid above 10 FC. You can adjust salt at any time. The others can always wait as they're long term concerns and with a SLAM afoot, folks have bigger fish to fry.I want to raise my salt to 3200 for Hayward T-15 SWG. I was advised to wait for slam to be done. Can I add salt today? That why I’m asking if salt readings are accurate at SLAM fc levels
