This sounds like the same type of setup for the jandy relay board. Correct me if I'm wrong here...you need a 2 pin wire connected to an empty relay slot and the other end connected to the midtex unit. Additionally you need a power supply wire connecting to the 24V slot on the power supply and again, the other end to the midtex unit. And lastly, the actuator wire connected to the midtex as well.
My only question is, are there connectors built into the midtex unit (like the jandy relay board) so that the actuator cord, power supply and connection to the relay slot plug right into it or do you have to cut off the mini plug on the end and strip wires to connect them via screw downs or some other type of connection. Also, do you know where to get connector wires with either 2 pin or 3 pin plugs built in already (assuming they can be used on the midtex unit).
Thanks for all the help!!!
