Pentair Intellichlor IC40 not lower output when pressed
baraider
8
Houston
Pentair Intellichlor IC-40
Hi all,
Need your help.
I have a new pool with new equipment but the installers are not the smart bunch and rarely shown up since they installed the equipment so we are left figuring this things out.
This is our first ever pool so everything is new to us.
I have IC40 connected to a EasyTouch control panel. I use the ScreenLogic app on my iPhone to monitor and change settings.
1) I have been trying to lower the output of the SWCG for months but after pressing and holding the Lower button, it goes to 20%-40% for a few seconds and got back to 100%.
Can't turn off by pressing Low/Up at same time.
I think the EasyTouch panel control the output but there is no setting in myScreenLogic app allowing me to change this.
2) Is there another app I can use on my Mac or another computer to get into the brain of the EasyTouch to configure things properly. I don't think the system set up correctly.
Thanks a bunch.
Answer my first question. I can go to the EasyTouch panel and change the chlorine output there.
Here is the youtube video showing how.
After changing it down to 0%, the led indicators on my SWCG still full on at 100%. Is this expected?
B,
I doubt it... Are they flashing?? If so that means you are at less than 10% It is also not an instantaneous change..
And.. As you have found out... When connected to an automation system the buttons on the cell itself, will no longer change the % of output.
B,
You are right. I just checked and the % led at the bottom are off while the flow led are on. So it's not instantaneous change but it does correspond to the changes made via the panel.
Thanks Jim
