Hey all! Thanks in advance for any help you can offer.
I've got a small inground pool ~ 13k gallons. I decided to discard all the old equipment and start fresh with a new system.
1.) Pentair superflo VS 1.5 hp pump
2.) Pentair Clean and Clear RP 150 sq ft cartridge filter
3.) Hayward H Series 200k BTU heater
4.) Hayward Aquarite salt chlorinator
I think I have a good grasp on how to plumb the system, so I'm not too worried about that aspect. (yes I will have a check valve between heater and salt, and also a sacrificial anode).
What I'm struggling to figure out is how to wire the system.
I have a dual 20 amp breaker in my panel in the basement. So that is 230 volt power. (Though the pump, heater and salt can all run either 115 or 230).
My old system had a timer with wire running to pump and then from pump to heater. So it was all in series.
Do I wire the new system in series as well?
The pump has a built in timer. I think it can run 24 hours a day (mostly at lowest speed). Can the heater and salt system get power 24 hours as well?
Do I need an intermatic timer at all?
Is there a reasonably priced automation system that will control all of this?
I love saving money by doing things like this myself.. but unlike nearly every other project I've done, it seems like there is NOT a lot of good info on the internet for wiring/controlling pool systems.
