I'm glad to be starting my first year using the TFP Method!! In short, last season I closed the pool with high CYA issues/problems with maintaining FC and my plan was to open it up in 2018 and do a 75% drain and refill. The issue I had last year was I couldn't maintain an FC level so the pool store had me using chlorine that had trichlor in it to shock. In addition, I was using the pucks that had trichlor in them. This did havoc to my CYA and even more to my wallet. I was never aware of the effects of CYA on chlorine until I visited this site. I came to this Forum at that time to see what I can do and it was recommended I just call it a year and start over in 2018. Flashforward to now:
I opened our pool beginning of May and did the re-fill. I successfully got the CYA down to 45. Once I achieved this my plan was to SLAMM it so it was ready for the summer. I started this on May 12th and since haven't stopped. I have maintained an FC level of around 18 and the water is pretty clear. The only item I am having issues is sustaining the FC level and I can't pass the overnight test. I have read this can take some time but I just want to see if anyone has any pointers and can verify I am doing this the right away. I have vacuumed the pool completely, scrubbed sides, clean lights, skimmers/flaps, and washed our steps. Once I had everything vacuumed I took the filter out and put a clean set in. I am using a taylor K-2006c test kit. I also have a Vinyl cover so during the day I should not have any loss from the sun. Here are my numbers since I started. Once I complete the Slamm I will deal with PH and TA. Any help is appreciated - THank you!
May 12 @ 6pm
Added 20l liquid chlorine
FC 4.2
CC .4
PH 8+
TA 170
Added 15l LC
May 12 @ 8:20
FC 16
CC 1.5
Added 5L LC
May 13 @ 10:20
FC 14.5
CC 1.5
CYA 45
Add 10l Liquid chlroine
May 14 @1
FC 14
CC1
TA 150
PH 8
CH 190
SI .25
Added 5l LC
May 14 @8pm
FC 16.5
CC 1
Added 6L bleach
May 15 @ 12pm
FC 16
CC .5
Add 5l LC
May 15 @ 9pm
FC 18.5
CC <.5 (barely turned red)
Overnight test
Pool vacuum / cleaned filter
May 16 @ 8am
FC 15
CC <.5
Added 2.5l LC
May 16 at 7pm
FC 14
Cc .7
7.5l LC
Pool Vacuum
Put clean filters in
May 16 at 10pm
Fc 18.5
Cc .5
2.5l LC
May 17 at 12pm
Fc 16.5
Cc .5
Added 2.5L LC
May 17 @8PM
FC 18.5
CC .7
CYA 45
Add 3l LC
May 17 @ 10:30pm
FC 22.5
Cc .5
Overnight test
May 18 @ 5am
Fc 19
Cc 0
May 18 @12:47pm
Fc 17.5
CC .5
Added 3L LC
May 12 @ 6pm
FC 4.2
CC .4
PH 8+
TA 170
Added 15l LC
May 12 @ 8:20
FC 16
CC 1.5
Added 5L LC
May 13 @ 10:20
FC 14.5
CC 1.5
CYA 45
May 14 @1
FC 14
CC1
TA 150
PH 8
CH 190
SI .25
Added 5l LC
May 14 @8pm
FC 16.5
CC 1
Added 6L bleach
May 15 @ 12pm
FC 16
CC .5
Add 5l LC
May 15 @ 9pm
FC 18.5
Overnight test
May 16 @ 8am
FC 15
CC <.5
Added 2.5l LC
May 16 at 7pm
FC 14
Cc .7
7.5l LC
Pool Vacuum
May 16 at 10pm
Fc 18.5
Cc .5
2.5l LC
May 17 at 12pm
Fc 16.5
Cc .5
Added 2.5L LC
May 17 @8PM
FC 18.5
CC .7
CYA 45
Add 3l LC
May 17 @ 10:30pm
FC 22.5
Cc .5
Overnight test
May 18 @ 5am
Fc 19
Cc 0
May 18 @12:47pm
Fc 17.5
CC .5
Added 3L LC
