- Aug 2, 2023
- 6
- Vinyl
- Jandy Aquapure 1400
Pool was finished a few months ago and just opened 2 weeks ago. Tested today and salt is low (1926, target range is 2800-3200), CYA is low at 17, and total alkalinity is high at 118. We’re going to add needed salt as the first step, but here are my questions:
1. Do kids need to wait to swim after adding salt? If so, how long? I need to add 141lbs of salt, which seems like a lot!
2. Pool Math app says to add 6lbs of dry stabilizer due to low CYA. Do I need that right away too, or wait and see what CYA reading is after getting salt where it needs to be?
3. Pool Math also says to lower alkalinity by adding acid to reduce pH, then aerate to increase pH again. Do I need to do that too, or again can I wait to see what tests look like after getting salt in range?
