Results 1 to 13 of 13
Thread: Help with pump
    May 2015
    Novi MI
    61
    Help with pump
    I have a Hayward super pump. Power is getting to the pump but it just makes a whining sound and then breaker trips if I leave it on too long. How can I fix it?
    26,700 gal (rectangular 18" x 36', CES 3'10" x 4'), IG, Vinyl, Hayward Super pump 1.5HP, sand filter-Hayward S244T, built roughly 5yrs ago I think, 1 1/2" pipe, TF-100, Well and city water available.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Help with pump
    Likely the capacitor, the centrifigul switch or bad windings in the motor, I would start with testing the capacitor.
    May 2015
    Novi MI
    61
    Re: Help with pump
    Where do I get parts for it? Is it better to fix or buy new? If I buy new what brand? Pool is 26700 gallons.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Help with pump
    If it's the capacitor, that should be an easy fix. If it turns out to be the windings in the motor, you may be looking at a new motor - I would get a price for fixing vs. replacement just to have the facts, though. If you do get a new motor, I would replace it with one of the same Service Factor HP (SFHP) rating if you will be using the same pump (the wet end) with a new motor. Also, replace the shaft seal if you get a new motor.
    This article has more info on pumps and further explains the SFHP rating: Pump Basics
    May 2015
    Novi MI
    61
    Re: Help with pump
    Where do I get a capacitor or do I take it to a repair shop? Do pool stores fix it?
    May 2015
    Novi MI
    61
    Re: Help with pump
    My pump is a hayward 1.5HP pump but sounds like it's too big? Pool is 18' x 36' not including the steps (rectangle pool). Is variable or multiple speed a lot more expensive than single speed?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Help with pump
    It is a bit big, I would suggest swapping out the single speed motor for a 2 speed, should cost under $400, maybe under $350 mail order. Best thing about swapping motors is it can usually be done without disconnecting any plumbing, only 8 bolts to deal with plus the wiring.
    May 2015
    Novi MI
    61
    Re: Help with pump
    I tested the capacitor and tried a new one and still it's humming. What is the next thing I should test?
    May 2015
    Novi MI
    61
    Re: Help with pump
    I need either a new motor or get a new pump. What's the better route? I have a hayward Super pump 1.5HP. Can I replace just the motor with either a 2 speed or variable speed motor? If a new pump should I get a VS or 2 speed? What I'm looking for is quiet and energy efficient. If I get a VS can I set it to the lowest speed 24/7 and will it cost less and will it cycle the water or too slow?
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Re: Help with pump
    As said in a previous post, if you replace the motor make sure it has the same HP and SF or more. Under sizing a motor can burn out a motor. A VS is the way to go.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Jun 2012
    western NY
    1,561
    Re: Help with pump
    your first post said whining and the last one said humming. The former indicates it is running and may have a bad bearing. Humming is either a bad start cap, bad centrifugal switch on the end of the motor or a jammed up impeller. Does the impeller turn free by hand?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    May 2015
    Novi MI
    61
    Re: Help with pump
    I'm sorry it's a humming and doesn't start. I replaced the capacitor and same issue. How do I test the centrifugal switch and what does it look like? I will see if the impeller turns freely by hand. If it does or does not what does it mean? Thank you.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Help with pump
    If it's humming it might be jammed with debris.
    remove the motor from the pump with the power off and see if you can turn the impeller.
    mine hummed once during winter and somehow a clump of pine needles was the cause.
    Dolphin E10 Cleaning Robot.
