- Mar 29, 2024
- 13
- Vinyl
- CircuPool RJ-30
I was replacing my pool pump. It is 220v. I have two red wires and one green wire (ground). I plugged the red wires into L1 and L2. There was also a screw on L1. I had a brain fart and wired the ground wire to L1. When I started the pump, I had a loud pop in my Control/breaker box and the breaker tripped. I realized my error and corrected it. When I reset the breaker and try to start the pump, it still pops and trips the breaker. I replaced the breaker and still having same issue. Have I fried the pump motor or have I possibly just burned a wire or caused a short. Any ideas? By the way, it also trips the main 50 amp breaker that supplies the control/breaker box (Hayward Aqua Plus box).
