Results 1 to 15 of 15
Thread: Site issues this morning
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    Is anyone having issues with the forum this morning? I keep getting "Resource Limit Reached". If I refresh a couple of times the site comes up then when I click a link the same message.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Site issues this morning
    Yes. They are working on it. It is a glitch from the server change yesterday. It is annoying. I am sure they will have it fixed soon.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Oct 2012
    605
    Thanks for the heads up AZGirl71!
    May 2015
    Chicago, IL
    508
    Yes it is quite annoying, but I am trying to get to the bottom of the issue.
    I apologize for any inconvenience this is causing anyone.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    No problem. I have had the message at least 50 times already. Red and Ozzy are working on it.
    Lisa
    May 2015
    Chicago, IL
    508
    OK I hope (fingers crossed) the 508 issue is resolved. I want to give it awhile before making any other changes.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,028
    Good deal Ozzy! You guys rock!
    I havent had the error in a while now.
    Quote Originally Posted by ozzy47 View Post
    Divin Dave,
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I have not had any errors either. Pages loading slower though.
    Lisa
    May 2015
    Chicago, IL
    508
    Yeah, working on load times now. This happens when you change one thing, it affects another. It's a wonder I have any hair left.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I figured as much. I hope your hair can be saved...lol
    Lisa
    May 2015
    Wildorado Texas
    252
    Quote Originally Posted by Azgirl71 View Post
    Now everyone knows why I long ago decided to keep mine shaved off!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Lol. Much easier.
    Lisa
    Pops37's Avatar
    May 2013
    North central TX (Tarrant County)
    108
    I see this error warning when I load the HOME page: Warning: Illegal string offset 'results' in ..../packages/vbcms/widget/myfriends.php on line 222
    Gunite/plaster pool w/spa built 1983, 17,000 gal. (depth 3' x 6' x 3') (37' X 16' +spa, stairs & large in-pool bench seat). Arneson (now Hayward) pool vac (rebuilt 3 or 4 times over 30 years), 350k BTU (nat gas) XE heater (in need of a serious herbal cleansing lol), 2HP Marathon pump & filter basket, DE filter NSS-48, air pump for spa bubbles, one skimmer plus in-line filter Hayward CANISTER W560 to the pool vac. Re-plastered May 2013 reinforced quartz (Marbletite) Diamond Bright. Test kit: Taylor K-2006; Bleach
    May 2015
    Chicago, IL
    508
    I will look into that when I get the page load times sorted.
    May 2015
    Wildorado Texas
    252
    Thanks Pops for that information.
