Results 1 to 16 of 16
Thread: What are the depths of your pool
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    We are doing a play pool
    3-5-4 and some are saying 3 is too shallow?
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
    38,268
    Re: What are the depths of your pool
    This has been discussed in many many threads ... try the search function and you will find them
    Mar 2015
    rowlett, tx
    853
    Thanks!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Mine is 3.5 sloping to 9'
    Essential Links:
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    3.5 sloping to 7
    I wouldn't go less than 3.5 unless you're hosting lots of crumb grabbers.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    4 foot wall height is the lowest I'd ever go in the shallow end. That means about 3 foot water depth. Nice for wading and smaller kids. YMMV if you want shallower water.
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    We have 3-1/2x5x4 and if I had it to do again it would be 4x5x4. That is just right!
    Jul 2014
    Peoria, IL
    389
    4 1/2' all the way.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Mar 2013
    New Hampshire
    351
    3'.5" to 8' but knowing what I know now I would go deeper in the shallow end.
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    3.5 - 6 ft water depth.
    If I had it to do over, I would do 4 ft on shallow end.
    Divin Dave,
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    3.5 to a rapid downward to 9'
    never been in a pool that drops down so quickly...kinda like it.
    Dolphin E10 Cleaning Robot.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Borjis: That sounds like a diving well!!!! Those are fun, but better for the higher, up-and-down gymnastic dives rather than the see-how-far-you-can-fly-out-in-front type of dives! Ouch..... Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    haha ya exactly.
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Mine is currently being built but it is 3'6" - 5' - 4'6" . I wanted 5.6" in the center but the PB talked me out of it because of the slope. - I have a large tanning ledge that takes up the "end" of my shallow.
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
    Sandissimos's Avatar
    Aug 2014
    Brighton, England
    76
    Ours is 5 foot depth pool throughout, meaning the water level is about 4' 8" approximately.
    12' x 24' IG approx 9.5k gallons
    4' 8" constant depth, vinyl liner, air to water heat pump, floating solar cover, 1 skimmer, 2 inlets, 1 underwater LED light, sand filtration system & now, finally, a TF100 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Love my deep end...even fishing out leaves. Diving is still fun to me.
    Essential Links:
